Question for Faceit usage
Hello, do you officially support it by any chance? I have tried a software “ExitLag” which works well, your model is more attractive ! if you can officially add all the IP ranges also make sure the anticheat supports the software.
Thank you.
last time i checked, they had support for faceit servers
From topics I have read well users have to manually deposit IP addresses + i’m unsure if the VPN would be ok with anticheat, it was blocked (according to a reddit user) i want to be sure it’s A-OK.
Many people who have internet problem playing CS2 would benefit from the service.
For exemple there are no Germany - Hetzner servers, which cause issues for some.
Thank you.
I’d set a trial credit now for your account. :slight_smile: So I think you can use all mudfish nodes and features for a while.
Mudfish should support Faceit but I’m not sure that your game server is also supported. Please try to test with trial credits and let me know if there are any problems or questions.
