I am getting very high ping with mudfish, i was not playing r6 for a while, but when i started today like after 1 year ping very high. is there any problem kindly see?
with full vpn also same high ping
i think siege has changed servers cos earlier it was south east asia now its ap southeast-1
if i select full vpn mode and apex legends server ap southeast-1 then pings are lower kindly look into the issue plz
Okay. If Full VPN mode makes some difference, it means something is missing in the game item of Mudfish. If possible, please check Packet Capture with Mudfish link and send us some game packets. We need it to analyze the game traffics.
Sent the packet capture with wireshark to support@loxch.com
as mudfish packet dump was giving internal error. also if u want the packet capture file link here i can give.
followed this- Packet Capture with Wireshark — Mudfish 4.3.8 documentation
its fixed now. Back to low pings huge respect. Thank You
Another thing siege has also added ap south-1 server mumbai
kindly add this also
Hello again! Thanks for letting me know about the new Mumbai server for Siege.
To add this new server to Mudfish, I need to analyze the game traffic first. Could you please send me another packet dump while playing on the ap-south-1 server?
You can follow the guide here: Packet Capture with Mudfish. If the internal dump gives you an error again, a Wireshark capture like last time works perfectly too!
Thanks for your help!
sent the packet capture using wireshark in the mail as earlier,
connected to the new server ap south-1 and also played a game for 2 mins in the new server ap south-1.
Updated by adding “Asia (Mumbai)” destination. Thank you for your packet dump.
When you get a chance, please test and let me know if it doesn’t work properly.
Ok played for a couple of days and i should say pings are perfect 26 - 35 in mumbai servers. Tq
