I get disconnected from the game server randomly in the middle of matches while using mudfish even when the ping is shown stable in the game. I tried changing node a couple of times (basic mode), but did not help.
New to Mudfish, so I’m not so sure what else should I be checking out for fixing it or if the disconnections are related to something else (disconnections normally dont happen without mudfish). Thanks in advance.
Sadly, the experience is somehow worse in full VPN mode. For a lot of matches, I’d get disconnected from the server right before the matches are about to start (can happen even with people from my own region).
Tried without full VPN mode today again. I don’t know if random disconnections could’ve occurred again in a longer session, but I did not get disconnected playing for around 1 hour today. Quite confused at this point.
Did you try to change a mudfish node based on FAQ - Nodes section for your game item?
