realtime traffic is not stable.. what should i do?
- change your node
https://mudfish.net/forums/6/topics/44662
Connection Protocol in TCPs
https://mudfish.net/forums/6/topics/37597
- run Mudfish with option lowercase `-s`
then access to https://ui.mudfish.net:8282
- China https://mudfish.net/forums/6/topics/44662 https://mudfish.net/forums/6/topics/37597
