It’s taking really long time and went over 400 “n” until I decided to try a different option
“Auto-configuration” could be completed while n_checked value is less than 5.
So if it goes over 5, it means there’s something wrong with Mudfish. Might be related to “Auto Selection” option of the mudfish node for the item configuration.
Did you see any other error or warning messages from Mudfish?
