Hi,
Recently I’m unable to connect to RU Europe Adelina & Adelina 2 nodes. I was using them to play/to connect BDO Mena from Japan but unable to for a while.
I do appreciate any help in advance.
Hi,
@furkanzdm As you might know, mudfish RU nodes are being suffered by the network block of Russia goverment. So if it starts not to work with these nodes, I recommend to use other mudfish nodes instead.
However did you try to use these RU nodes for the connection from Japan to Europe?
Thanks for the reply.
I do try to connect from Japan to Turkiye (Istanbul & Bursa), which BDO Mena servers supposed to be located. And I’ve tried another node from Russia which is from St.Petersburg and works well, except higher ping. What I think is, block is not happening between Russia to Turkiye or exact versa, but from Japan to some-node-between to Russia or connection is not done at all.
There are no regulations against Russia, nor Ukraine between Turkiye. TR is being neutral to war. So there shouldn’t be any network block to mena servers between RU and TR. In fact, I can try and surf Turkish websites with RU nodes and VPNs with no issue.
