Seems not working for China any longer. Any comments or fix?
Please try to
- connect to Hong Kong or Taiwan https://mudfish.net/forums/6/topics/44662
- Connection Protocol in TCPs https://mudfish.net/forums/6/topics/37597
- run Mudfish with option lowercase `-s` then access to https://ui.mudfish.net:8282
- China
