Settings Error?
Hello, i have been using Mudfish for a couple of years now to play League of Legends.
Summary:
-Connection Based
-Items to Apply: League of Legends
-Node: Basic Node
I also have Fast Connect Mode, Full VPN Mode and WFP Item Mode turned OFF.
But when i visit websites, they show my location in Hong Kong (mudfish location, i am located in Singapore).
This creates an unnecessary problem where i cannot access certain region-locked websites and i have to disconnect Mudfish first.
Problem being, i leave my game client online 24/7.
Is there some specific setting i can adjust/tweak so that Mudfish will only apply to League of Legends and i can browse and surf the net normally without intereference?
Thank you!
@dappy Did you try to turn on WFP Item mode and check that it works fine with your PC? If it works fine, I think it’s what you’re looking for.
I think the issue you’re encountering is CDN and Mudfish in my opinion.
