These SOCKS5 server is dead.
Please fix it.
Connection test command
# curl http://api.ipify.org -x socks5://username:password@node-jp-00387.mudfish.net:18081
curl: (97) connection to proxy closed
Dead server list
node-jp-00111.mudfish.net
node-jp-00206.mudfish.net
node-jp-00046.mudfish.net
node-jp-00482.mudfish.net
node-jp-00654.mudfish.net
node-jp-00134.mudfish.net
node-jp-00319.mudfish.net
node-jp-00207.mudfish.net
node-jp-00011.mudfish.net
node-jp-00033.mudfish.net
node-jp-00432.mudfish.net
node-jp-00479.mudfish.net
node-jp-00247.mudfish.net
node-jp-00483.mudfish.net
node-jp-00031.mudfish.net
node-jp-00388.mudfish.net
node-jp-00036.mudfish.net
node-jp-00651.mudfish.net
node-jp-00465.mudfish.net
node-jp-00636.mudfish.net
node-jp-00619.mudfish.net
node-jp-00331.mudfish.net
node-jp-00622.mudfish.net
Still not working.
24 hours already passed.
Please fix it as soon as possible.
@f7ym5ehr Is it still same? Unfortunately I can’t produce your issue at my end because it works fine. And your command via curl also works fine on my box. Might be your IP blocked by ISP level? At least no blocking from Mudfish.
If you’re familiar with the packet dump, I think you can try to captue some packets and analyze which the step it causes.
It is works successfully now.
No, before Apr 14 connection works successfully.
After Apr 14, connection lost.
I dont’t know why.
I already curl proxy connection test from other VPS service provider’s VPS.
It’s same result.
I think, SOCKS5 is sometimes unstable.
FYI
Hi.
ServerIP: 104.198.127.37 is dead ?
Please fix it.
This is Linux curl socks5 connection test command.
# Not working
curl http://api.ipify.org -x socks5://username:password@104.198.127.37:18081
# Working
curl http://api.ipify.org -x socks5://username:password@34.84.172.146:18081
Got it. However it’s not easy to explain why it’s happening on your side. When this issue happens again, please try to do the packet dump. It’ll show more details about why.
system
Closed
May 9, 2023, 4:55am
7
