sometime, product subscription League of Legends (China) the TW Asia (Taiwan - Google 1 ~ 3) can’t connect.
yes, Full VPN mode and too.
and VPN so LAG.
Umm… Then did you check Which a mudfish node is best to connect the China game server? section too because you’re connecting to China game server?
Yes, I have. I did not have this problem before.
Then did you check Connection Protocols too? When I checked your account, you’re using TCP based protocol. I don’t think LoL works well with TCP so you should use UDP based connection protocol.
i have checked.
It seems you’re still using TCP protocol. Did you see any difference with UDP? What was your ping with UDP based?
TCP and UDP too,all protocol can’t connect.
Weird… At this moment did you check How to check the basic functionality too with TW Asia (Taiwan - Google 1 ~ 3) nodes? If it works fine, it means the game publisher blocked the mudfish nodes.
sometime can connect,sometime can’t.
At this moment I can’t figure out why sometimes it works or not. Did you see any warning and error messages at the core logs of ‘Status -> Process’ menu?
