Prior to January 19/20, 2024 my South Korean node for full vpn using the Throne and Liberty launcher only has around 70-80ms ping. But right now, i have lots of nodes and it is now at 129-130 almost double of what it was. Any help on this? thank you!
Which a mudfish node did you use? Did you try to change a mudfish node based on FAQ - Nodes section?
how do i determine if i am using advanced mode?
On my summary bar it says
full vpn
fast connect mode
wfp item code
Are you using Full VPN mode enabled? Then it’s not possible to use the advanced mode for mudfish nodes because it’s only for the item settings when Full VPN mode turns off.
