[STDOUT]
[0.006000] [INFO] mudfish v4.4.5 (for x86_64)
[0.007000] [INFO] Timestamp: Fri Aug 04 20:26:18 2017
[0.007000] [INFO] Full VPN mode is enabled
[0.007000] [INFO] Connection protocol: udp
[0.008000] [INFO] Authenticating…
[0.062003] [INFO] Fetching the static nodes…
[0.520030] [INFO] Fetched 307 static nodes from the master.
[0.526030] [INFO] TAP-Win32 Driver GUID {275552EA-43CF-4EB0-95DD-90766D814D4E}
[0.526030] [INFO] TAP-Win32 Driver Version 9.9
[0.527030] [INFO] TAP-Win32 Driver MTU 1500
[0.527030] [INFO] Setting TAP-Win32 Adapter v9’s MTU to 1450
[0.632036] [INFO] TAP-Win32 Driver TcpNoDelay disabled
[0.632036] [INFO] TAP-Win32 Driver TcpAckFrequency not found
[0.633036] [INFO] TAP-Win32 Driver TCPNoDelay not found
[0.633036] [INFO] TAP-Win32 Driver TcpAckFrequency is set with 1. Reboot is required to take effect.
[0.634036] [INFO] TAP-Win32 Driver TCPNoDelay is set with 1. Reboot is required to take effect.
[0.650037] [ERROR] MUDEC_00196: SID 199 ((null)) isn’t alive.
[0.650037] [INFO] Setting the default gateway as 10.255.32.1 (199 (null))
[0.651037] [ERROR] MUDEC_00309: Failed to write the routing socket message: 51 Network is unreachable
[0.652037] [INFO] Ready
[0.741042] [INFO] Listening the management console at 127.0.0.1:2897
[1.652094] [INFO] Waiting until the client’s ready to handle the routing path list.
[4.652266] [INFO] Waiting until the client’s ready to handle the routing path list.
[5.491314] [INFO] DHCP discover for 00:ff:27:55:52:ea (PC-20170406KAFQ) from interface
[5.491314] [INFO] DNS address: 8.8.4.4
[5.492314] [INFO] DHCP request for 00:ff:27:55:52:ea (PC-20170406KAFQ) from interface
[5.492314] [INFO] DNS address: 8.8.4.4
[5.492314] [INFO] DHCP Client got IPv4 address now
[7.652438] [INFO] MFP 0 FlowMTU - 14.63.214.216 1500
[STDERR]
지금 게속 미꾸라지 사용하면 디스코드는 남의 말이나 채팅 보여지는데
제가 쓰는글이나 음성도 전달안되고
심지어 인터넷 페이지 네이버도 호스트 알아내는중이라며 인터넷도안됩니다
왜이러는거죠 ?갑자기 오늘부터 그러네요
