It was literally working fine until I turned it off. Unable to turn it back on, stuck at RTT calculation and the n_checked portion is ticking one every minute or so. Does not seem to be a problem with my firewall as far as I know.
It’s still down, check the other 2 recent posts. There’s nothing the mods can do cause this is the original provider fault.
It was up since 7 hours ago. I was able to connect.
I could once or twice but it’s very rare and sometimes it dc abruptedly. I went and get free trial for exitlag until this is fully fixed.
me too i have the same problem , stuck on RTT for 30 min
I was able to connect, and have been connected since 2 hours ago. Packet loss seems to be prominent, something I haven’t experienced throughout my usage of mudfish until now.
@vhenkhr2 For your issue, I think your issue is related with your data plan because I can see you’re encountering MUDEC_00330 errors in Mudfish side. Please check the link for details.
