Hello I was using mudfish to play maplestory but after disconnecting and checking on it a few hours later I went from around 30gb left to negative 545 yen which is around negative 40-50gb if I recall properly as can be seen here my daily usage is usually in the mb range, is there anything that can be done?
Thank you for reaching out! I’ve posted my response in the Private Support section under the topic you created. Could you please take a look there at your convenience? ![]()
You can find your topics here: Sign In - MUDFISH: Acceleration As a Service
