Tap-win32アダプターを使わずにMudfishを使う方法はありますか?
Sorry for answering in English because we’re not offering technical support with other languages.
I’m not sure is there a way to run Mudfish without TAP driver.
Please follow the steps if you get any problems:
Confirm that if pass How to check the basic
functionality
then check where the program is in C:\Program Files (x86)\Mudfish Cloud VPN\
or not and are mudfish.exe / mudflow.exe into the path then
execute Mudfish VPN Launcher at Start Menu than any shortcut what you’ve
created.
- Please download a driver in 32-bit or 64-bit for your system
static.loxch.com/tools/tap0901-i386.zip
(32 bit)
static.loxch.com/tools/tap0901-x86_64.zip
(64 bit)
Extract it then run remove.bat
Run install.bat
