i use full vpn mode also disable ipv6 protocol, choose singpore and china node to connect singpore server.
I can access the game, but i have connection lost issue randomly.
How to solve this?
How to solve this?
i don’t know how, i switch vpn protocol from udp to tcp, now there is no more connection lost issue.
@rayark2016 It’s not easy to explain if changing Connection Protocols from UDP to TCP is working for you. If then normally your MTU (Maximum Transmission Unit) size could affect your issue.
Not sure that the following steps is helpful but please try when you get a chance.
ok i will try it thx
