Currently getting server connection lost when trying to connect to a match on tarkov but I was able to connect a week ago. I can only connect using Multi path node, which takes too long to connect and I get kicked from tarkov servers due to high ping.
@PascalArturooo When I reviewed your configuration, here’s my opinions:
- It seems you’re using TCP protocol for Connection Protocols. Is there any reason? I think UDP is definitely better if it works because Tarkov is a UDP-based game.
- It looks you’re using 800 bytes MTU under ‘Setup -> Program’ menu while our default MTU is 1400 bytes currently. Please try to change it to the default value and test.
