Is it better to use TCP or UDP for MMO games like Final Fantasy 14? I’ve tried using fast connect for UDP but it doesn’t seem to work for me. TCP works slightly better but I don’t know which is better to use.
As you know FFXIV is a TCP based game so it’s fine to use TCP connection protocol if it works properly. So its result between UDP and TCP is almost same.
When you get a chance, please check Connection Protocols link for details.
