hi, im a new mudfish user, it seems that the packet loss is bad regardless the node that i choose, I played SG server from indonesia, even i chose the lowest score node, its still packet lossing, is it my network problem that is so bad that it cant be helped? Also, the data consumption is quite big, even though I have only tried it to make sure its working properly
I think u should try advanced mode and try ID asia node to sg node instead of basic mode directly to sg since indonesia might not have the best infrastructure network around the country (routing wise)
might want to try udp protocol as well.
Please try to test your network status from your desktop to 45.76.149.99 (the public IP of SG Asia (Singapore - Vultr 2) mudfish node) using How to use WinMTR link.
