Is this working? I kept getting the cdn or something warning, by far this shows the least ping, others all shows TL.exe multiple instances with high ping..
I am using selecting item TL (korea) with fast connect and wep. I do note that theres a 111 ping on the very first one. Is this working or not at all?
Can u post a help on how do I use any node to play this on smooth ping?
On exit lag I can get 67ms constant ping, however with mudfish, its hard to even know if it is working.
Normally I would say everything is pretty easy to test with ingame ping however for throne and liberty theres no option to show ping ingame except from resource monitor, this is absolute frustration… Because I do not know whether my bandwidth is being charge for consuming but the node is not working.
If someone play ncsoft throne and liberty and have a good setup let me know and share with me how u did it thank you I appreciate.
Okay. If all ping points 0 ms from TL.exe, it means that the connections are redirected to mudwfp_proxy.exe.
So I think:
TL game is properly working with Mudfish.
With mudfish, it seems it’s not easy to know the real ping via the resource monitor because it only shows RTT between your desktop and mudfish node. It doesn’t know the RTT from mudfish node to the game server.
Hi, i feel that even thou mudwfp_proxy.exe show 80 ping, but it is not working. i feel that i am still having 230+ ping and the 80 is not real ping. Do you feel any improvement of ping in game?
If you’re using WFP Item mode, I think you don’t need to use FastConnect mode. However according to the screenshot, I think it’s applied to the game properly.
it shows 5ms here now after update. weongyo, do you have any idea how to test our ping to Throne and Liberty server manually? because resource monitor wont show the real ping?
However did you try to run ping 35.72.40.92 from Command Prompt while Mudfish was running? I’m guessing that this 35.72.40.92 IP is one of game server IPs.
No perfect answer for this question. If your data plan is PPT, please make sure that you checked CDN and Mudfish issue because you could encounter this issue.
However if your data plan is SUB (subscription), please be aware that you could encounter MUDEC_00330 if your subscription voucher is low-level.
If that is the game server IP, how come the ping is same when i use mud fish and i dont use mudfish? it should be different isnt it? i suppose to get lower when i turn on mudfish right?
Actually now i feel that i can play the game smoothly with mudfish, but why the ping still show same when i ping 35.72.40.92 with or without mudfish?
