There is some problem using UDP protocol for those 2 servers, TCP works fine.
SG Asia (Singapore - Google)
SG Asia (Singapore - Google 2)
I have changed MTU for my ethernet from 1400 ~ 900 it can’t be fixed.
This happened only with those 2 google nodes, i tried other server in SG, HostUS, aliyun, etc there is no problem and i can play the game, if i use the 2 google node i can’t even ping the game servers (internap).
Can you check and fix it?
Thanks
