using Los Angeles nodes for FFXIV (Primal), the pings are working fine via cmd, but the login screen never loads, and when I tried to login with the vpn off, the characters in character selection never loads, it’s like the connection is there, but the download is set to 0 or something like that
Please try to change your Connection Protocol
- Are you running any Mac Operating System? github.com/Homebrew/homebrew/issues/31153
Please try to
enable Full VPN
mode -
use
-Ooption to change the Mudfish’s working method as refer
Firewall - Mudfish
Master
Server
consider to change MAC
Address -
consider reducing
MTU from
1450
