Using Mudfish for XBox by Internet Connection Sharing
Hi, i follow the steps “How to use Mudfish on PS4 or Xbox”
On step 3.3 after i turn on sharing and select the adapter where my xbox is connected… the adapter is getting static ip 192.168.137.1 without default gateway. However my Xbox ip is automatic and its not getting ip and its not working.
Pls advise what to do.
@jeffreyjimenez17 I think the latest document for that link is here.
Please check it again when you get a chance.
For this question, could you please explain how you get 192.168.137.1? Because I don’t know any knowledge about your network arch., I think my opinion could be wrong. If you’re setting IP address statically instead DHCP, I think you can also set IP address statically at your Xbox too.
192.168.137.1 is automatically assigned to the laptop Ethernet adapter where my Xbox is connected.
