As the title would suggest, whenever I use mudfish (for playing Lost Ark in South East Asia connecting to NA West) the entire household wifi gets slow. An illustration is as follows: (1) I turn on Mudfish Lost Ark); (2) other devices connected to the wifi will have slow internet (or sometimes momentarily be disconnected);
I find this really odd considering that mudfish is only installed and running in my computer. Is there a remedy to this so that only my computer would be connected to the VPN?
I will try this. On this matter, would you happen to have any advise as to what Connection Protocol I should use? I’m not so knowledgeable regarding this area lol.
I’m only using Mudfish for playing Lost Ark to reduce latency connected from South East Asia to North America West (Oregon)
2.) And then when all of the options indicated therein was not fixing it, I tried the “Connecting Mudfish from China” solution found here: Connecting Mudfish in China - Mudfish Wiki
2.1) I downloaded the Mudfish DNS client
2.2) I flushed my DNS
2.3) restarted my computer
I suspect that perhaps my ISP was blocking my connection to mudfish (Not sure but I suspect it so)
Thanks! after days from my reply above, it would seem that the result is a hit or miss. After doing the above solution, sometimes connecting to the mudfish nodes would work and sometimes it doesn’t. The usual error that would pop is something about “network firewall”.
Whenever that error pops up, the entire household wifi would not work. So its a hit or miss.
