Hello,
I would like to know if it is possible to have the VPN working for a single application.
As an example, I want to have the VPN datas to only cover and be used by a game that has an IP block for the area where I live (Europe).
The item does exist. It is called Dragon Quest X. Fast Connect Mode does not act as VPN, and full VPN mode will make my entire browsing go through the VPN, using much more data that I would like it to.
Is it possible, or is full VPN mode the only way to have a VPN running under Mudfish ?
Thanks.
So I looked around and it seems I have to have Full VPN activated but enable WFP Item Mode. Do I still need to add the process name of the specific program I want mudfish to be using ? Or will the item just suffice since Dragon Quest X is an item.
I added every app I could think of to the WFP exception (chrome.exe, discord.exe, steam.exe etc…) and I believe this is how it works.
