Using Turkey Node but it detected as canada
Hello
I trying use Full mode VPN with TR Europe node (Bursa - OneProvider)
but it ended up give me a IP to canada instead of turkey
can a support check this and fix this ?
You’d better try using another relay server located in Turkey(Istanbul - Hostinger).
That one not available on full vpn mode
But I tested today it work properly now idk why
If the database that identifies location information based on ip is not up to date, such problems may occur.
https://ip-api.com/#185.123.101.121
