VALORANT - How do I check my ping for each node?
I’m trying to connect to Singapore/Mumbai in Valorant, but the table isn’t updated and I’ll have to manually check them one by one which is a pain. I can get the ping from resource manager via windows but how can I use that ping to check the ping from each nodes? I’ve checked your documentations but it doesn’t really help
@crianichia Did you try to use http://ping.mudfish.net/ link? If you know the game server IP, you can check it at there.
