This has been happening for over two months.
First of all, launching Mudfish kills my internet connection for some time.
I have been tried all the solutions for errors like changing nodes, starting the program with -t and/or -o parameters, cheked my firewall, av, updates, drivers, etc…
My provider (Mobile TeleSystems Open Joint Stock Company) tells there is no problem on their end.
some logs:
[STDOUT]
[0.008995] [INFO] mudfish v5.4.3 (for x86_64)
[0.010993] [INFO] Timestamp: Tue May 4 22:19:29 2021
[0.011993] [INFO] Connection protocol: tcp
[0.012992] [INFO] Authenticating…
[0.631717] [INFO] Fetching the static nodes…
[2.961056] [INFO] Fetched 528 static nodes from the master.
[2.968051] [INFO] TAP-Win32 Driver GUID {CBFAB21C-27F9-4CAD-8168-FCD6B2A12ABD}
[2.968051] [INFO] TAP-Win32 Driver Version 9.9
[2.968051] [INFO] TAP-Win32 Driver MTU 1500
[2.969049] [INFO] Setting TAP-Win32 Adapter v9’s MTU to 1400
[3.030498] [INFO] TAP-Win32 Driver TcpNoDelay diabled
[3.031501] [INFO] TAP-Win32 Driver TcpAckFrequency 1
[3.031501] [INFO] TAP-Win32 Driver TCPNoDelay 1
[3.039493] [INFO] Uses the macaddr for msk(4) (cached).
[3.086464] [INFO] Ready
[3.089461] [INFO] udp_relay: listening on 0.0.0.0:1 (fd 0)
[3.089461] [INFO] tcp_relay: listening on 0.0.0.0:1 (fd 0)
[3.094459] [INFO] Waiting until the client’s ready to handle the routing path list.
[3.180404] [INFO] Listening the management console at 127.0.0.1:52205
[6.072663] [INFO] DHCP request for 00:ff:cb:fa:b2:1c (Notebook) from interface
[6.115631] [INFO] Waiting until the client’s ready to handle the routing path list.
[6.125625] [INFO] DHCP discover for 00:ff:cb:fa:b2:1c (Notebook) from interface
[6.142614] [INFO] DHCP request for 00:ff:cb:fa:b2:1c (Notebook) from interface
[6.142614] [INFO] DHCP Client got IPv4 address now
[6.760496] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[6.761497] [INFO] TCP relay from the client (10.254.41.92:53731) to the backend ((null):(null)) failed.
[6.763492] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[6.764490] [INFO] TCP relay from the client (10.254.41.92:63211) to the backend ((null):(null)) failed.
[6.971760] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[6.972752] [INFO] TCP relay from the client (10.254.41.92:63211) to the backend ((null):(null)) failed.
[6.975850] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[6.975850] [INFO] TCP relay from the client (10.254.41.92:53803) to the backend ((null):(null)) failed.
[7.187981] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.187981] [INFO] TCP relay from the client (10.254.41.92:63211) to the backend ((null):(null)) failed.
[7.189916] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.189916] [INFO] TCP relay from the client (10.254.41.92:63333) to the backend ((null):(null)) failed.
[7.406055] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.406055] [INFO] TCP relay from the client (10.254.41.92:57865) to the backend ((null):(null)) failed.
[7.407058] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.407058] [INFO] TCP relay from the client (10.254.41.92:59767) to the backend ((null):(null)) failed.
[7.612098] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.612098] [INFO] TCP relay from the client (10.254.41.92:63357) to the backend ((null):(null)) failed.
[7.615102] [INFO] tcprelay: Failed to find SID for destination 192.168.8.1.
[7.616102] [INFO] TCP relay from the client (10.254.41.92:49628) to the backend ((null):(null)) failed.
[9.118281] [INFO] MFP 0 RouteAdd - 109.244.5.0 255.255.255.0 170 102 0 n -1
[9.119282] [INFO] Fetching new static node SID 170…
[10.021692] [INFO] re121: Associating with ip 46.101.236.104 port 10008
[10.022688] [INFO] MFP 0 RouteAdd - 124.150.157.0 255.255.255.0 170 102 0 n -1
[10.023689] [INFO] MFP 0 RouteAdd - 183.111.189.0 255.255.255.0 170 102 0 n -1
[10.023689] [INFO] MFP 0 RouteAdd - 195.82.50.0 255.255.255.0 170 102 0 n -1
[10.024688] [INFO] MFP 0 RouteAdd - 204.2.229.0 255.255.255.0 170 102 0 n -1
[10.026686] [INFO] MFP 562 FishInterfaceBind - 170
[10.026686] [INFO] MFP 564 FishInterfaceBind - 170
[10.027686] [INFO] MFP 566 FishInterfaceBind - 170
[10.027686] [INFO] MFP 568 FishInterfaceBind - 170
[10.027686] [INFO] MFP 570 FishInterfaceBind - 170
[10.027686] [INFO] MFP 572 FishInterfaceBind - 170
[10.027686] [INFO] MFP 0 FlowMTU - 14.63.214.216 1500
[10.117320] [INFO] re121: Connected to 46.101.236.104:10008 (TCP)
[STDERR]
Empty file.
