Hi I have a question for using Mudfish… I am a new user
Basically i would like the best result from Mudfish for playing TERA.
However, TERA SEA Server has a region block for where i live (Hong Kong), would the ping be reduced if i use the same node for both VPN mode & under item (Tera)? Also, will using advance mode / multi-path mode make tera detect a sudden change of IP?
Thank you for any helpful tips.
