WFP issue
Hello,
I have a problem that when I use WFP mode in Final Fantasy 14 the ping stays the same as when I have mudfish disabled. When I turn off WFP mode the ping stays low as expected. Is there a way to have WFP mode enabled and low ping? I could do it a few months ago
Could you please send me Problem Report while this issue is happening? I need to check the internal logs.
Done.
I’d left my answer on another topic you created on the Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
Thank you for everything!
