What is supposed to better, lower ping or lower RTT/RTT STD?
One server has 49 ping when i ping it via CMD and the other one has 55 ping, but mudfish shows the 55 ping one has lower RTT.
Which one is more important if i play blade and soul?
Hey, thanks for the answer.
So i should disable fast connect and find the best server via “Realtime RTT”?
Also it recommended to enable fast connect back after finding the best server for the game i play?
It won’t show Realtime RTT when if enabled FastConnect mode docs.mudfish.net/en/docs/mudfish-features/fastconnect-mode/#my-realtime-rtt-graph-is-gone
FastConnect mode is for TCP Connection Protocol so I guess you should set your connection protocol to TCP to apply FastConnect mode
Picking TCP over UDP makes my ping go from 50-55 to 100+ in game even though blade and soul uses TCP.(The same with or without fast connect.)
If there are any firewalls then please try to
enable Full VPN
mode
use -O
option to change the Mudfish’s working method as refer
Firewall - Mudfish
Master
Server
consider reducing
MTU from
1450
How to reset TCP/IP by using the NetShell
utility
Windows XP with SP3 and some Vista, 7 or 8 configurations — ‘Cannot
reach Sites’
mudfish.net/forums/6/topics/33571
consider to change MAC
Address
