whats wrong with mudfish to Blade and Soul… it was good at first 2 weeks… and now, it so damn unstable ping and it keeps me disconected from the game…
It’s good to see as reference. And please check “Status -> Nodes” menu to see your RTT average and stddev values between your desktop and mudfish nodes. Is RTT stddev closer to 0 (zero) to internationa nodes?
it keeps dc nowadays, suddenly no traffic in realtime traffic dashboard, and it happens alot…
네. 우선은 Full VPN 모드는 사용하지 말고 중계 서버를 변경하시면서 시도를 해보시길 권해 드립니다. 혹시나 그래도 여전히 문제가 있으시면 말씀해 주세요.
- Please download and install latest Mudfish at https://mudfish.net/download
- What about after release white/blacklisted Mudfish Node(s)?
- What about Full VPN mode?
I did use the latest mudfish version which is 4.6.1. I'm not sure what you mean by releasing black and white nodes? I'm using white nodes. I'm not using vpn mode but I will try it out and see.
- Run as administrator then wait for about 10 seconds to 5 minutes
- run `netsh winsock reset` as administrator https://support.microsoft.com/en-us/help/299357/how-to-reset-tcp-ip-by-using-the-netshell-utility
- run Mudfish with option lowercase `-s`
then access to https://ui.mudfish.net:8282
- China https://mudfish.net/forums/6/topics/44662 https://mudfish.net/forums/6/topics/37597
패킷 덤프 보내주셔서 감사합니다. :-) 제가 아이템 업데이트를 해보았는데 한번 테스트 부탁드리겠습니다. 시도해 보시고 여전히 제대로 동작을 하지 않는다면 말씀해 주세요.
