When will indonesia node fixed? all 3 nodes are bad, CLDREU and Sukabumi got packet loss, and serverkeren really high ping. So sad no support for Indonesian user
Sorry for this inconvenience.
However I’m not sure how your connection could be stable because when I checked your RTT information, it seems your ISP also has an issue to the international line. Did you check your ISP too?
Only an option I can suggest is that leasing more indonesia servers for mudfish nodes. I’ll try to lease more again.
Yeah my isp is having problem with international connection since last month so I used mudfish route, but since last week the node really unstable sometimes packet loss / high ping / normal between that 3. Tonight the sukabumi is perfect, cldreu packet loss, serverkeren high ping
처리해 드렸습니다.
확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
음… 혹시 패킷 덤프를 진행하실 때 게임 또한 진행하신 것이 맞으신가요? 제가 알기로 롤의 경우 UDP 기반 게임으로 알고 있는데요, 먼가 게임 패킷으로 생각이 되는 부분이 적습니다. ㅠ.ㅠ
