while running mudfish will it only vpn the data from the game im playing? i like to listen to videos on youtube while playing and i don’t want to eat my traffic balance.
how do i check what my ping is if the game doesn’t have any way of showing ping?
if you equip the game as an item, it’ll only route the date to/from the game and leave other connections alone. If you use Full VPN, it will route all traffic.
You can try to Create Custom
Item
as refer Unsupported
Games
Take a look and find the daemon process what you want to apply
Mudfish in Status → Memory
Then create a Custom Item as input the process name like
P:AProcessName.exe
Please try to change your Connection
Protocol
