why i use connection protocal UDP play tera keep DC
and i use TCP good…but UDP ping ok and i love use UDP protocal…can u fix this
same nodes…use connection protocal UDP play tera keep dc…
use connection protocal TCP no dc…
i want use protocal UDP
Could you explain which nodes you used and encountered this issue?
However if I understand correctly TERA is based on TCP protocol. So connection protocol TCP would be fine for that game. :-)
