Why is it always stuck 47%?
t400
Private Network test: KR Asia (S. Korea - KT1 IDC)
Performs the private network test against KR Asia (S. Korea - KT1 IDC). If you encounter this issue, please see below t401 section for solutions.
t401
Private Network test: JP Asia (Tokyo - SoftBank)
Performas the private network test against JP Asia (Tokyo - SoftBank).
If this marked as X, please check the following items:
- Sometimes MUDEC_00044 and MUDEC_00045 error codes causes this issue too. It means that your operating system isn't ready to pass packets to mudfish though mudfish is already ready to receive.
- Make sure that JP Asia (Tokyo - SoftBank) node is alive. VPN Server status link is for you.
- Make sure that above t100 (Core proces is ready) is marked as OK. If it's not marked as OK, these tests could also be failed.
