Why the connection is so unsta
Why the connection is so unstable? One day i have 230ms and others i get 270ms+ Why the same settings… Please, i am paying for the service… It should work perfectly all the time -.-
When I checked this graph, it seems you’re running other processes causing network activities. And too much traffics on mudfish side (based on Realtime Traffic).
However with this, you can’t check your RTT (Round Trip Time). Please check ‘Status -> Nodes’ menu to see RTT average and RTT stddev (Standard deviation). And please try to use a node whose RTT stddev is very stable.
환불에 필요한 정보를 알려주시면 확인 후 처리하겠습니다.
환불 정책
mk9853 / 부산은행 / 242-12-029762-3 / 김주원 입니다
처리해 드렸습니다. :slight_smile: 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
