You will be introduced Japanese Tree of Savior do?
Sure. When you get a chance, please send me some game packets using Packet Capture with Mudfish. After analyzing I can add it for you. :-)
Is it even same? I can’t find any reason you can’t see any nodes.
Never mind, it was probably some weird temporary server downtime or something. It’s fine now.
Recently I’d updated the game item for LOST ARK. Did you test it again?
ok ~ normal! Thank you
loxch Why do you ignore messages about profile update black desert online korea? The server has changed IP, the old BDO profile does not work !!! You need to update it.I wrote you a new IP address here too
I didn’t ignore other feedbacks. However even if it doesn’t work with Full VPN mode enabled, it means no ways to play the game with mudfish.
However I’d updated the game item based on your information but no gurantee that it works.
올바른 UDID인지 확인해 보시기 바랍니다.
UDID는 영숫자 40자리
또는 숫자8자리-영숫자16자리
형식으로 이루어져 있습니다.
관리자님이 전에 답글로 달라주신 IPA 다운받아서 설치하는데 어플 다운은 돼었는데 대기중… 이렇게만 떠있고 설치 작업이 되지 않습니다.
그리고 UDID는 아이패드 어플중 dev info라는 어플로 확인시
A687E94E-7E6F-4E68-9C49-CDF5EAA3C0EF
이렇게 나오고요
아이튠즈로 확인시
afbf8c15cfedaef54e91b6df6a41c741dca3a652
이렇게 나옵니다.
