your nodes for path of exile has been very unstable since last month. please fix
Please try to FastConnect mode for Path of Exile
still not fixed. all singapore nodes are above 1 rtt std. even reaches 10. before you had a lot of nodes under 1. many stable nodes. now theres none.
all nodes now from singapore are unplayable. rtt std is 5 - 20
What about Full VPN mode?
connection still bad even with full vpn. its fine for the first 30 mins but then became unstable again. 80 up to 300 ms
Please try to change Connection Protocols
i tried all ports like you suggested but still doesnt work. singapore nodes are so bad now. japan sometimes works but only for a few minutes then it breaks. what happened? it wasnt like this last month.
