Is there any submarine cable issue on your ISP side? I have no idea how 120 ~ 150 ping was possible between ZA and SG.
Please try to turn on “Include the result for the advanced mode” option which found under ‘Setup → Nodes’ menu. When it’s enabled, Today’s Pathes will show you the advanced results for route pathes.
This is what the ping is now (keep in mind i cannot select a server above 195ms latency) The Singapore used to be below 150ms Latency so i was able to select the server.
Im still using the same Setting as always Datakeepers - Linode (Vultr,Leaseweb to name a few)
No i used another program to reduce the ping in game (it doesn’t work with the launcher, Where you Need to change the server) Used to work for over a year using Mudfish.
@Skalas I see. However please note that at least there’s no any changes on Mudfish nodes. That’s one thing I can guarantee because I didn’t update at all.
So in my opinion, your issue is triggered by other things which we can’t control. Might be there’s a problem in the international submarine cable or the upsteam ISPs were changed their routing policy.
I’ll try to look for a internet line which it works good between ZA and SG.
