before 5.4.3 after connecting mudfish and refreshing the nodes, I manually select a node that I want to use by checking ping. sometimes the lowest ping node has heavy load. so I usually pick out second or third node.
In new version I cannot check ping but only node names so am I doing something wrong? or is that supposed to work that way?
I’m using mudfish to play final fantasy XIV
Please check my answer at the following topic.
