Need Help with Mudfish VPN Setup for Lower Ping?
Hey everyone,
I’m new to Mudfish and trying to set it up for better ping in online games, but I’m a bit confused with the settings.
Here are my questions:
Should I use Full VPN mode or just select the game item: ?? Which one is better for performance: ??
How do I find the best Mudfish node for my game: ?? Is there a way to test different nodes efficiently: ??
Does Mudfish automatically adjust the best route, or do I need to manually tweak it for the lowest ping: ??
Any specific settings that worked well for others using Mudfish: ??
I would really appreciate any advice from experienced users !! I have also searched on the forum for the solution related to my query and found this thread https://forums.mudfish.net/t/no-change-in-ping-after-using-mudfish-same-ping-as-isp-react-native but couldn’t get enough solution.
Thanks in advance. :blush:
Looking forward to your responses !!
If your game is supported by Mudfish, then you can select the game item. However sometimes the game item could not work because of various reasons including 1) the outdated game item 2) the game server move to the another location 3) something is changed internally in the game itself and 4) etc.. For these cases, you need to play it with Full VPN mode as a temporary solution.
No perfect answer for this question because it’s very vary depending on which ISP you’re using or how is the international cable condition good. :slight_smile: Please check FAQ - Nodes document first and test with various combinations.
No. I don’t think there’s an easy way to compare the mudfish nodes. I think it requires your manual test.
For this question, you need to check the following links because it’s up to the node mode; Basic Mode (uses 1 mudfish node to route), Advanced Mode and Multi Path Mode
