background : Princess Connect Re:Dive connection problem.
As Cygames keeps updating their VPN block list, i believe that the last viable node is also disable today. Is there anything mudfish can help with this since i really like the mudfish VPN service which allows you to maintain normal activity while connect VPN.
Thanks!
Sad to hear that… As you might guess, this issue isn’t easy to solve unless we find other server providers and lease their servers…
