It has been months since you tell me that you will investigate this problem, but it’s still not fixed yet.
Recently I’ve tried ‘full VPN mode enabled’, ‘change Connection Protocols to TCP based’ and
‘try to use other mudfish nodes’, but none of these help.
It’s pretty annoying that I can’t participate to 기사단, and so as my friends who also use mudfish, so please check and fix this issue. Thank you.
@Vrin Yep… As you might guess, no luck for this issue. If it doesn’t work with Full VPN mode enabled, it means most of features by mudfish doesn’t work too.
@Vrin As you might guess, I think this issue is only happening with mudfish. And in my opinion it seems the game publisher blocked mudfish nodes tightly. So in my opinion, it looks we need new KR public IP to bypass their restriction. Let me check this little bit more.
